Any Help Dh Dishes
derint
67
I will be pointing 3 dishes tomorrow
Dish 1 – 4.5m w/ dual beam feed. Satellites: G12 @ 133* / AMC 10 @ 135*
Dish 2 – 4.5m w/ tri beam feed. Satellites: G13 @ 127* / G14 @ 125* / G18 @ 123*
Dish 3 – 3.8m w/ dual beam feed. Satellite AMC 18 @ 105* / SES 1 @ 101*
Any pointer to save time will be welcomed
Zip code 77422
2 degree spacing is pretty tight, especially on a 3 beam setup. Do you already have the modded feeds/scalars for this? If you do, then things should go well. You know your zipcode so you can do a quick lookup at the dishpointer website using the link at the top of the page and look for targets to aim at as well as the dish elevation for the area.
Finally Cut The Cord!
Do the Discovery Suite channels on W5 end on 1 June, or 30 June?
