cheebs said:I have had 3 of them go bad. They download the update, reboot, and when it's time to load the guide, it just searches for signal. Same symptom with all 3 ird's... any thoughts?![]()
raoul5788 said:If all three showed the same symptoms, I would suspect another problem, like bad wiring or a loose connection somewhere. Possibly the dish is misaligned.
I'm sorry, for this question . Which update are we talking about? Are you forcing it ?cheebs said:I have had 3 of them go bad. They download the update, reboot, and when it's time to load the guide, it just searches for signal. Same symptom with all 3 ird's... any thoughts?![]()
cheebs said:nope, nope and nope. 3 different locations, all worked fine before they took the update. I'm stumped, H10 works fine at same said locations.
rockaway1836 said:I'm sorry, for this question . Which update are we talking about? Are you forcing it ?
lou_do said:Go to your setup and make sure the right dish (3-LNB - 5-LNB or other choices) is selected. We had ours get changed during an update and had the same problem. Once we selected the right dish, everything came back.
Just a thought and thing you can check.
gct said:It took me three H20's before I got one that worked both on the HDMI and component outputs. That was in April - talking with the tech support folks back then, it seemed they knew they had a bad batch of hardware.
