Apple Support Community Shuts Down After 28 Years, Forums Removed Entirely
These companies are SO arrogant. Apple probably got pissed that regular people turned out to be more knowledgeable than the Apple "experts"....also got pissed because this community board allowed Apple product owners to figure out ways around Apple's "suggestions" not to mention all the things Apple tries to sneak in with updates.
Years ago I was on the Viasat community forum. Viasat employees were CONSTANTLY giving out inaccurate information. I would pop into the discussion and give the right answer or steer them in the right direction. I did all my own ordering, did all sales in the store, and I did my own installs and service calls so I was about as expert as you could be when it came to all things Viasat, plus I was on the dealer council. Did Viasat fire those employees since they clearly didn't understand the product or their jobs?? Heck no, Viasat booted me off the forum and blocked anyone from reading any threads that were over a certain number of days old.
I never thought that any of the so called geniuses at the genius bar were smart lol.
What bothers me here is that when Gemini makes a specious claim, the citation it links to too frequently doesn't support the assertion. Come to think of it, this happens most often with Reddit citations.
In the DIRECTV subreddit in particular, there have been quite a few instances where the initial post is deleted, yet the responses remain.
Because it's an interpretation. One of the fundamental things to learn about AI is deterministic vs non deterministic behavior. When you ask it something, you're getting a non-deterministic response, meaning it is interpreting and providing a response based on processing that data. That doesn't mean it will always be accurate or that it will be the same every time.
An example - if you wanted a report created from a set of data, you don't use a LLM for that, because you don't want the data interpreted every time you pull that report, no you want that data consistently reported on. So you use a LLM to create the script / mechanism / page / etc so that it pulls and creates that report every single time - a deterministic action - rather than asking for the data to be interpreted every time.
It may seem like a simple thing, but once you understand the concept, it makes some sense why you see variability in things from time to time or anomalies like what you caution against here.
There are other wrinkles as well - the model presents the answer to a query, then attaches the closest-looking source, which doesn't always actually support it. Reddit makes this worse when the OP is deleted, because the model is reading replies without the original question.
And then after all of that, it doesn't mean the data (training or references) is even correct ;)
On the topic overall though - it's just a matter of learning the tool. Learning when to check and further interrogate your sources - just like 'knowing how to Google'.
What other tool hallucinates? Having to engage in an extended chat to arrive at what you hope is a valid answer is scary at best. How much refinement is not enough?
Even scarier, AI has shown some propensity to double down on its hallucinations.
How's that fundamentally different from any other tool? Just asking that shows that you understand the potential limitations. How is that any different from knowing when to stop Googling for an answer, or when to follow up with someone who's offered advice, instead of just taking the first search or the first answer at face value? The biggest difference is with AI you can ask why and interrogate the answers as much as you want without bothering anyone or anything.
It's kind of like anything else: trust but verify. And just like anything else, trust is earned. It has earned your skepticism, and that's alright.
Reactions: AZ.
Other tools do what you expect them to do without having to follow up with "seriously?".
When I say tools, I'm not talking just AI tools. I'm talking about everything from SD card ejectors on up. AI as a tool that is rapidly becoming overwhelmingly less "trusty" than my Leatherman.
Prior to AI Overviews and the like, a web search engine returned only the content it had crawled. Now you have to visit its links to see if it was asserting something was supported by a citation when it clearly wasn't (assuming that you have the wherewithal/background to tell the difference).
And to think how dismissive people are about Wikipedia!
You picked a Leatherman, which does the same thing every time. But plenty of tools don't. A stud finder throws false positives constantly, and nobody stops calling it a tool. They knock on the wall or drill a pilot hole first. Using it well means knowing how it fails and when to double-check. With AI, the check is clicking the source, not asking it "are you sure?" You're right that Overviews made that harder, but that's a reason to learn the tool's limits, not a reason it isn't one.
What helped me most was thinking about deterministic vs. non-deterministic tasks. When you reach for a Leatherman, you want the same result every time: unscrew this, cut that. A web search or asking a person is different. You get an interpretation, and it can change each time. If you can't tolerate that fuzziness, including hallucinations or alternative facts, you need a deterministic tool. That doesn't make AI useless there. For me, it often means using AI to help build the script, report, or query that gives the exact same result every time.
A false positive from a stud finder is rarely repeatable and can be tested statistically, whereas something intentionally misleading from AI takes considerably more diligence. That same AI may help you verify (or dismiss) it, or it may double down. Brad holes are easy to cover, but the same isn't true of your reputation.
Web crawling isn't perfect because people post misinformation. The difference is that AI reputation isn't trackable, and the answer may differ with each query.
Fair point that the same question can get a different answer twice. I'd actually call that a feature. If two runs disagree, that's your cue to verify, same as sweeping the wall a second time when the stud finder beeps somewhere weird.
I'd push back on "intentionally misleading" though. There's no intent. It's confidently wrong sometimes, the same way a stud finder confidently reads a water pipe as a stud.
And reliability is tracked. Error and hallucination rates get benchmarked and published constantly, and they've dropped a lot.
The reputation part is the same for both tools. You don't hang a TV on one beep, and you don't repost an AI answer without checking it. The tool doesn't own my reputation. I do.
Error and hallucination rates are perhaps as rare as DIRECTV quarterly financial reports. I've only seen a couple, and those were for self-hosted LLMs.
It doesn't require much time or effort to sweep over a suspected stud multiple times. Ultimately, the answer is binary; it is either there or it isn't.
Certainty about an AI query requires coming up with a different question/hypotheses and working off those results. The solution (or whether there is one) is highly dependent on the chain of questions you ask. Getting a definitive answer can lead to a research project.
178 sites spread malware unknowingly this week
