Birdog Perfect Vision for setting up 1000.2
chapin4life
91
Hi guys I struggled 2 days to get 129w on a 1000.2 and was only able to get 110 and 119 setup
do you guys think its worth getting a Birdog, someone is offering me one for $100 used.
Double check your Skew and elevation. Also make sure your mount is level. Peak the 119 and the other two usually fall in line. If it's just one time set up I'd have a hard time justifying $100 for a meter
Sent From My Samsung Hercules
On the check switch, in what order are your sats? It should be 119 110 129.
Sent from my iPad 2 using Forum Runner
There are 1000's of worse ways to spend $100 with nothing to show for. If it will help you, get it, use it & then resell it.
LNB Drift Detected
Anybody ever ordered service through GWDish.com?
