If you have a clear day this weekend, follow the sun across the sky from your intended dish mounting location. The sun should cross due south at just about 1pm local time. If it is not obstructed by trees at any time during the sun's transit from 11am to 4pm local time, you should have a clear view of the domestic satellite arc. We are very close to the time of the year when the sun follows the same elevation as the satellite arc, causing outages from a few seconds to 10 or 15 minutes per day on each satellite, peaking early next week. Before then, the sun will be 1 or 2 degrees ABOVE the arc, but makes a good marker that requires nothing but observing what time it is, and note any time of day that trees or other obstructions block direct viewing of the sun from any location.
If you want a better idea of where the sun is throughout the year, anywhere in the world, the U.S. Naval Observatory's website has a custom calculator.
Just do a search for U.S. Naval Observatory and you should be in business.
