c band LOF/L settings on dreambox receiver
cruzin
323
michigan
Hi, does anyone know what the settings on lnb set up for a dreambox receiver would be for c band. It has 3 fields to fill in and I know what one is I think. these are the 3 fields to fill inl
LOF/L LOF/H threshold. I believe the LOF/h would be 5150 but not for sure. Anyone using a dreambox on c band? thanks for help. I am using a GeoSat pro C2 lnbf.
C Band is 5150
I'd set both High and Low to 5150
Is there a setting for LNB type: Universal or Standard?
If so, select Standard
"Threshold" is used for a Universal LNB where you ave 2 L.O.: 9750 and 10600
hey thanks Lak7, I tried setting all to 5150. so what you think I should set that threshold at? or just leave it 5150
C Band is 5150
The Threshold setting is the point it should switch between Low and High bands for a Universal LNB.
C Band does not use it, so I think it does not matter what you put in there.
83 Sat
Is Sadoun website down?
