Can I use a combination antenna for this location?
Mark A Sparks
593
3
East Tennessee
Hello,
My tv fool report below. Can I use a combination UHF / VHF for this setup? Need suggestions on which antenna and amplifier to buy. THANKS!
boba
11,350
1,036
Dorchester, TX.
Hello,
What is the question you are asking you need both VHF and UHF. You can use both a combination antenna or separate UHF and VHF HI. After looking at www.antennaweb.org You need both VHF HI and LOW TVFool shows 5 and 27 NBC with the same call letters and same broadcast location, Antenna web only shows ch 5.
Mark A Sparks
593
3
East Tennessee
Any recomendations for a VHF HI and UHF combination ? Do you recommend a seperate booster, if yes what kind ?
Tank
Dec 13, 2004
Glendive, MT
He really wouldnt need VHF LO
5 is the original station but they have a translator on 29 at the same location. Since it shows decent numbers on the tvfool he could use that instead
stardust3
8,730
7,187
That changed, before the transition deadline 5 was broadcasting on 28 uhf. They are on 5 vhf now.
I stand corrected, you're right............5 is on 29 uhf. Wonder when it changed?
Mark A Sparks
593
3
East Tennessee
stardust3
8,730
7,187
I did have it combined with an 8 bay channel master UHF, but did away with it because this antenna works great by itself. No splitters.
I like that wineguard also, can't justify in fixing something that isn't broke or I'd try it.
How far apart should 2 antennas be and how should they be combined?
Gravity Sports Network
