Cancel Season Pass
I assume you mean HR20-700?
Anyway, hit the dash key twice. - -
There is no confirmation so make sure you mean it.
what dash key? :(
It's the same one you would hit if you were putting in your 13.1 the . part is the dash key.
Also I believe, if you go back into the series link record where you set it up originally, you will be able to cancel it there.
(I don't have mine on at the moment, so I cannot verify, this is from memory)
Jimbo
Ok I found the - button, but i still see no page in the menu to cancel a season pass, I want my TIVO back.
Ok, I have mine on so I can look at it, here ya go.
First, go to your "To Do " list, Highlight the one you want to cancel, then Select it, then go to Rec Series, "select" ... bottom right is an option to Cancel All. and that should do it.
Jimbo
There is no "page". When in the prioritiozer (season pass manager) simply highlight the series you want to cancel and hit the dash button twice. That's it. Series link is gone. That simple. :D
Alternate is if there are episodes showing next to the series link then you can select it and follow the steps Jimbos stated.
Whichever you prefer.
Recently Moved, lost local channels?
Audio drop outs
