Channel Master 75E Question
BiggRedd
36
South Texas
I have the Starband/DN version of the CM75E. Since I have a sub to neither anymore, I pulled off the Tx/Rx SB device along with the two DN LNBF's(119 & 110) and borrowed two working KU LNBF's from a friend to use on this dish to receive 1 or 2 satellites.
My problem: What is the focal point length? The arm is 18.75" overall and from the edge of the dish to the end is 16". I have tried just about everything to no avail.
I know lots of folks have converted this dish and claim it works well.
I just need a very, very simple straight forward example and/or explanation.
I don't have enough days left in my life for much more frustration!:)
Thanks very much!
That dish is KU band
Welcome to Satellite Guys !!!!:welcome
The dish you have it already KU band - - - all you need to do is just connect the receive portion and leave the Transmit disconnected.
These are great dishes and work well for FTA!
Use the Starband LNB and feed, note that the feedhorn is shaped to illuminate the entire dish, a regular Ku LNB is designed for a round dish and will either over or under illuminate an oval dish.
GL,Eric
I agree with Oldford, and if you don't want the original LNB, at least keep the original feedhorn. You should be able to attach any C-120-flanged LNB to the feed (might have to remove a waveguide first).
Fortec Dynamic Firmware?
sg2100 Noise
