Hello,
I was hoping I could get some feedback from you all kind folks for some hints to figure out what the heck is going on with my setup!
I have an FTA receiver (Microyal MRX-900, not yet updated, meaning it still has original factory s/w) set up with a fixed oval antenna with two LNBs.
I have two more antennas that I disconnected to convert a bigger problem into a few smaller ones. Set one at a time.
I'm first trying to receive signals from an "easy bird", or so I think, Telstar 5 aka Galaxy 25 from Miami (25.58.13N/80.9.37W): 97W 54ele. I use SAA software to check for this and some extra info like: TP3 has a FTA v-signal at 3757.
I bought an SF-99 to fine tune it and it appears to be very close,i.e. it peaks outside. But when I try to channel-scan my receiver signal never goes over 66.
So, several questions arise:
Are these the correct LNBs for this FTA receiver?
How do I know when to choose between normal, universal, LNBFs?
Antenna setup calls for 16 antennas. I assume it is one and use #1.
Then there are two freqs for LNB1 and LNB2!?
Tone can be set to None,0, or 22k. I've tried them all.
Now DisEqC has none and ports A thru D. I've tried one and A. And with one antenna trials I've kept it off.
Then just to make sure there is pandemonium there is a C/Ku band control with none and 0/22k.
Then for channel search a new page opens with:
Antenna. I use 1 (out of a possible 16).
Transponder. Used 1 then 3.
Freq. I used for Tp3 3757.
Symbol rate I've ignored. Don't know what to do with it!
Polarization I've used H and V. For Tp 3 I used V.
Then last but now least there is again the 22k deal?!
Now stir gently with mango and papaya juice and you get a hand pumped water well!
Clueless!
PS: Pls don't tell me to read the manual. I did. It is in English, written or tranlated from Chinese!
And I used to think that Japanese manuals were bad!
Help!
Clueless!
Help!
