cm7777 vs winegard 9370
Bulbman2
74
I have a cm4228 uhf antenna with a winegard 9370/ amp/pre-amp. I do receive all hd signals in a 60 mile radius and I am very happy with the performance.
My question is: I was reading the specs on a cm 7777 amp and was wondering if this amp has even better performance then I already receive. as I can not find any specs on the winegard 9370 amp.
Also, if the cm7777 has superior performance and I want to change it, do I need to change the pre amp also///??????
thanks
John
winegard 9370
the windgard 9370 is the power supply for the 8275 pre amp. it all works great- best uhf antenna set up I have ever used
Bulbman2 said:
I have a cm4228 uhf antenna with a winegard 8275/ amp/pre-amp. I do receive all hd signals in a 60 mile radius and I am very happy with the performance.
My question is: I was reading the specs on a cm 7777 amp and was wondering if this amp has even better performance then I already receive. as I can not find any specs on the winegard 8275 amp.
The two preamps have nearly identical specifications.
