Component Svideo simulateous output?
Beo
5
Can anyone tell me if the HR10-250 supports simulataneous output on component and svideo? Or does connecting component disable the svideo output?
It outputs both only in 480i. If you want HD and SD at the same time the HR10-250 doesn't do them both at the same time.
That is unfortunate. I was reading an interesting discussion on another forum discussing how to get the best picture quality out of SD. One of the points was that conversion of a NTSC signal onto component can cause additional loss of quality. If the tuner supports HD over component *simulataneous* with SD over svideo, you could set up your system to switch inputs depending on source (HD channel/recording, select component... SD channel/recording, select Svideo).
When will I get my locals on directv?
DirecTV Aims for Top of Pop World
