Component to composite
gdarwin
4,299
113
Lousville, KY
Anyone know of a cheap component to composite converter?
Moved a 942 to a tv that only has composite in.
The 942 doesn't have any composite out or s-video out? Composite to composite or s-video to RF modulator to TV would be the best and easiest way to go. You will get no better quality with a component to composite versus the cost.
That is what I ment by cheap. I've already found the high priced ones... TV2 is going to be used to feed other tvs.
Unfortunately because of the way the signals are different, I do not think a simple PnP adapter will be available for component to composite. That is why I think you should call a pro, RAM, directly.
Wall Mounting
Problem with my 1080p on my Mitsu WD-52628???
