Confirm AMC3@87W
magnigyro
326
Please confirm: I lost all channels in tp 11735 (Mta,M+3, Arabiya, info, etc)
I have very good signal Quality. Yesterday blank, today again.:eek:
I'm losing my French classes!:mad:
They are not there right now, I am running a scan to see if they moved transponders.
EDIT - The channels are still there but manual PID entry is required.
I noticed in a previous post that you said you have a Pansat 2500.
I have a Pansat 3500, I think the instructions should be the same or similar.
Do the following:
"Menu" -> "Installation" -> (Enter your password) -> "Advanced Scan" -> (Select AMC3 87 degrees or whatever yours is named) -> (Using the Arrow Keys select the 11736 8333 V transponder) -> (Arrow down to Video PID and enter the pid information from The_List 87.0°W AMC 3 Ku :) do the same for the Audio and PCR PIDS) -> Press Enter.
(Otherwise you can wait and they will probably fix the data stream, but we don't know how long that will take)
You have to do this for each channel you want :(
Do the following:
"Menu" -> "Installation" -> (Enter your password) -> "Advanced Scan" -> (Select AMC3 87 degrees or whatever yours is named) -> (Using the Arrow Keys select the 11736 8333 V transponder) -> (Arrow down to Video PID and enter the pid information from The_List 87.0°W AMC 3 Ku :) do the same for the Audio and PCR) -> Press Enter.
Yes Sr...I'm using a Pansat 2500, I'll do what you say immediately...
Thank you very much:)
Do the following:
I did it. the advanced scan makes them appear. However...the channels are not stored!!:(
Safe Tv On Galaxy 25
Oscilating signal
