Is Their A Way To Exit Guided Setup????
It Did Not Work It Just Made A Ding Sound....
I Got The Guided Setup To Exit Out And It Now Says Searching For Guide Data The Model Of The Receiver Is H23-600...
Yes.
But The Guided Setup Came Back Up...
k.
So you still can't get it to go past the searching for signal ?
Does your other recvr work ?
Yes I Have 2 Receivers The H21-100 Is Working Fine And The H23-600 Has This Problem....
Ok, can you move a working recvr to the location that is not working and try it ?
Yes. I All Ready Tried That Last Night....
And what happened ?
And what happened ?
It Worked....
If thats the case, did you happen to try putting the none working one at another location ?
It should NOT work there too then.
I have a feeling the unit has gone bad.
It Can't Be Bad Because When I Found Out How To Exit The Guided Setup It Found A Signal About 10 Minutes And When I Unpluged It And Plugged It Back In The Guided Setup Came Back Up I Went To The Setup Menu Then System Info I Found Something Saying Completion Code 8529.,.
You have a signal now ?
OK
Go into the System Info and run a test and see what it says.
I thought you said you had no signal ...
