Diagnostic Error Codes Issue
It Did Not Work It Just Made A Ding Sound....
Obviously you tried the Exit button....
Not sure why it's stuck, do a reset using the menus.
Menu, Set Up, System Set Up, Reset, Restart Recvr, dash.
This will do a proper reset and possibly clear any other issues you may have going on as well.
I Got The Guided Setup To Exit Out And It Now Says Searching For Guide Data The Model Of The Receiver Is H23-600...
If thats the case, did you happen to try putting the none working one at another location ?
It should NOT work there too then.
I have a feeling the unit has gone bad.
It Can't Be Bad Because When I Found Out How To Exit The Guided Setup It Found A Signal About 10 Minutes And When I Unpluged It And Plugged It Back In The Guided Setup Came Back Up I Went To The Setup Menu Then System Info I Found Something Saying Completion Code 8529.,.
You have a signal now ?
OK
Go into the System Info and run a test and see what it says.
I thought you said you had no signal ...
Can I put up a new dish without a 12/24 month contract?
Receiver problem
