I've went thru the manual ....I'm sure you've missed something, check with the manufacturer for setup info.
Check and check .... same manual they give you with the dish and Control unit.The UC-1000 is to make the King Quest VQ4 100 DTV Antenna to work with some Dish Receivers like 311,211vip series or 411
For DTV use,you will only be able to tune 101 Satellite
http://kingconnect.com/wp-content/uploads/2015/03/21961_Rev_A_Manual_VQ4100_COMPRESSED.pdf
Ok, I am Presuming with the UC1000 the dish will get both 101 and 119, now I'm wondering if it sees one or the other ... seeing when I had the box programmed for both I could not get any thing on the TV.There are several references on the kingquest web site to the use of the UC-1000 to get 119.
For example, in the QandA:
Does this pick up satellite 101 and119
1 answer(s)
by Vicki July 02, 2015
Out of the box this satellite antenna only picks up satellite 101°
Installation of King's UC1000 controller will add access to satellite 119°
and
Will this pick up Satelite 119?
1 answer(s)
by Anonymous May 12, 2015
No, this antenna requires the UC1000 controller to lock on satellite 119°. Without the optional controller, the antenna can only locate satellite 101°.
HR24I just went through the programming manual for the UC1000. You should get 101 and 119. Just like the Dish and Bell settings can be used for multisatellite.
What receiver are you using?
I actually was running it in dual tuner mode and had a coax from each side of the dish, into input 1 and 2 on the back of the HR24 ...Are you running it in single tuner mode, at least for now. If that works, you will need to connect the second tuner as per the diagram for a "second receiver".
1 answer(s)
and
1 answer(s)
This is the King Quest, I have never played with the other ones, came real close to buying an RV with one already on it, but that fell thru.I have never been successful setting the King Dome for DTV to lock on 101 & 119 for the Tucson Locals in this area for my customers at the RV Parks
Just try to run the primary line to your HR24 and setup the satellite configuration as a single tuner non-swm and then you could try 18x24
Tomorrow I will have to setup a brand new King Dome same model like yours on the roof of an RV to replace an old crank up Winegard for a customer from Tucson,but he did not bought the UC1000 controler
I do not remember if he is using an HR24 or H24 but is just the same receiver without the Hard Drive
Last time I saw him was back in April and this past Friday he setup and appointment for Monday morning
I will try to get back to this thread tomorrow or day after tomorrow with my findings
The instructions for the 119 for D* says to to set it up so that the 2 leds on the left of the 4 are lit up using the Scan button ... I did that part .Yes,that is correct but for Dish service not for DTV
Also the answer is not very clear for which provider by Anonymous
Next time when I get to play with a UC1000 controller I will try to check for the commands to the receiver if they are DiSEqC or 22Khz
No, those are for DirecTV. The setup instructions are actually very clear.Yes,that is correct but for Dish service not for DTV
It shouldn';t but I would simplify by trying single tuner first.I actually was running it in dual tuner mode and had a coax from each side of the dish, into input 1 and 2 on the back of the HR24 ...
Do you think it would make a difference ?
Iirc, theres not a setting for second recvr or dual tuner, just to connect coax to other post for 2nd recvr.
I was able to get the 101 very quickly, actually much faster than the recvr starting up.BTW I was wrong about the UC1000,my apologies for the mistake
The manual states that work for D******* for 101 and 119
The UC1000 controller replaces the power injector
Caution
Do not use with the power injector
If power injector is present,remove from the system before adding the controler
My customer brought a D12 receiver this time and the antenna lock on 101 right away
Does our location really make that much difference ?Signal average was 86 to 87
Average SD satellite dish for 101 is around 92 in this area and up to 96 for Slimline dish
My location 31°19?00?N 113°32?13?W
Regards
