DIRECTV Transponder Map ~ Data 7/23/2025
What are the "HD Occ" channels for? I found several of them in the smart search results and they all showed either the D* logo or a black screen. They also all had the option to launch the ScoreGuide.
Those are the feeds used for the part time sports channels that aren't repurposed from CINEHD, like the ESPN+ for Business channels that have a lot of back to back events during the fall
Reactions: lordodogg
DirecTV Satellite Transponder Updates for Jul 16 2025
Comparison of Transponder Data for Jul 16 2025 vs Jul 09 2025:
No changes in system tables for any transponder tuning parameters.
Changes to the use of defined transponders:
1 Transponder cleared of all Streams::
Net 10 TID 133 Beam NAT is a National Transponder on D11@99cb, TPN 10
Stream (PID) counts:
LIVE Streams​
National​
Spot Beams​
Count​
Change​
Count​
Change​
4K​
3​
HD​
274​
-2​
1445​
SD mpeg4
143​
198​
SD mpeg2
446​
-1​
RB​
Audio​
89​
Push​
25​
Slate​
21​
1​
TEST Streams​
National​
Spot Beams​
Count​
Change​
Count​
Change​
4K​
HD​
1​
SD mpeg4
1​
SD mpeg2
RB​
Engr Work​
25​
-7​
The PID count Excel workbook provides much more count detail.
Newly updated tables of Streams on each transponder are available in the DataDigesters TPN Grids
More details of changes in individual channels will follow in the Weekly Analysis
and Gary Toma's Domestic TPN Map Excel files
The OPEN sports channels in que
Some readjustments in TPNs
Weekly Analysis soon
Enjoy
DataDigesters
The Open Experience on 205.x, 601.x and the 900s
Some TPN reshuffling involving CBSe/WCBS, Marquee, Daystar, TUDN, Fuse and FOX Deportes
Passing along Gracenote's RF number update for KHGI Kearney, 2 years after the change actually happpened
9755 SWITCH out, 9758 *NETFLX in
I saw Open Mix channels while I was playing around some more with the Smart Search feature and they were subchannels of 205 and 600. Glad to see they are live now.
BTW, I'm not sure what they are doing with CINE 176. It says "to be announced" in the guide, and all I get is a black screen when I tune to it, rather than the Ku offline slate.
Directv subscribers lose KDQS Fox Duluth, MN yesterday due to contract dispute
An INFO channel about PANTAYA being discontinued on 7/31 is up as a Ku offline channel on channel 1947, just above PANTAYA itself on 1948. I think that is a Spanish-language SVOD service.
It's with Coastal Television, so it's also affecting the following stations:
Anchorage:
KTBY/4 FOX
(KYUR/13 ABC and KYUR-D2/13-2 CW were already in dispute with its actual owner Vision Alaska)
Elmira:
WJKP/39 MNT
WYDC/48 FOX
Fairbanks:
KATN/2 ABC
KATN-D2/2-2 FOX
Fargo:
KVRR/15 FOX
Jackson TN:
WNBJ/6 NBC
Jonesboro:
KJNB-D2/38 CBS
KJNB/39 FOX
Juneau:
KJUD/8 ABC
KJUD-D2/10 FOX
Lafayette IN:
WPBI-LP/16 FOX
WPBI-D2/17 NBC
WPBY-LD/35 ABC
Meridian MS:
WGBC/30 FOX
WGBC-D2/31 NBC
(WMDN/24 CBS was already in dispute with its actual owner Big Horn Television)
Tupelo:
WLOV/27 CW
Pantaya was purchased by TelevisaUnivision back in 2022 to create Vix, for the past year or so they weren't accepting new subscriptions as it was winding down the 3rd party contracts under its previous owner Hemisphere.
DirecTV Satellite Transponder Updates for Jul 23 2025
Comparison of Transponder Data for Jul 23 2025 vs Jul 16 2025:
LIVE Streams​
National​
Spot Beams​
Count​
Change​
Count​
Change​
4K​
3​
HD​
274​
1430​
-15​
SD mpeg4
142​
-1​
196​
-2​
SD mpeg2
446​
RB​
Audio​
89​
Push​
25​
Slate​
21​
1​
TEST Streams​
National​
Spot Beams​
Count​
Change​
Count​
Change​
4K​
HD​
1​
SD mpeg4
1​
SD mpeg2
1​
1​
RB​
Engr Work​
24​
-1​
Open Golf channels tucked away till next year
Not a lot otherwise
Enjoy
DataDigesters
The Coastal Television dispute is repurposing Drop Slide Channel 9221
Passing along Gracenote's RF updates for KTVMDT, also a year+ later
Correcting the TMSID for WJMN Marquette so it's pointing to the schedule data for their D3 MyNet subchannel instead of the WBUP/ABC simulcast on their main channel
CINE 176 is back in test mode
Dishpointer Pro "not licensed"
