dish 500 + 129 Legacy & Location
DataWave
36
11
K here is my situation:
I live about 30-45 mins (driving) north of Minnesota (thunder bay, ontario) I just ordered up myself a VIP722k to add to my sub. I am assuming I can hit 129 because I am so close to the border.
Would I require a larger pan (was thinking of using an old 18 inch dish), and also is this the correct setup for me for switches:
Currently I am running an SW44 for my dish 500, I was told to continue with that, and with say output 2 and output 3 of the sw44 run a cable each from those outputs to the inputs of 2 sw21s, then run 2 cables from the 129 dish into the other inputs of the sw21, then out to the vip722k?
Also is there a current footprint map of the ciel-2 bird around?
Ciel 2 footprint: http://www.satelliteguys.us/dish-network-forum/150304-ciel-129w-footprints.html#post1539478
K i found a 24 inch dish, got it pointed and got a signal (just waiting on the receiver to arrive), but still wondering if this is correct: Currently I am running an SW44 for my dish 500, I was told to continue with that, and with say output 2 and output 3 of the sw44 run a cable each from those outputs to the inputs of 2 sw21s, then run 2 cables from the 129 dish into the other inputs of the sw21, then out to the vip722k?
In theory it will work. Unless your other receivers are Legacy it might be a good time to upgrade your electronics also.
Thanks.. Guess I will find out in a few days ;). Ya one of these days I will upgrade to a Dishpro+ LNB and Switch
OTA Antenna
DVR Replacement
