dpptwin problems
Nope clear the matrix by running a check switch with the line in disconected. Then check the superdish option and run a check switch agian.
We have been getting a lot of service and trouble calls for this.
There seems to be a lot of issues with all of the SuperDish lnbf's due to heat here lately. I have seen failures with all of the lnbf's now.
This applies to DPP Twins or the Superdish LNBs for the matrix?
Side note:
It makes sense. Lot #T605 DPP Twins that were going around last week not one of them would work with a 322 reman no matter what you would do.
Today I noticed a new shipment of DPP Twins, you'll know it when you see one, you really have to squeeze to get them into the Y bracket. I'm thinking these are probably designed for the heat related issues.
Side note:
My fix is for when you get the 119 N.C. results on the DPP twin. This result is not a hardware issue, it's software.
Side note:
Yep, I've notice the DP Quads are now that way too.
I just take a flat-head screwdriver and slip it in on the bottom side and slide the LNB on.
Sorta like you would use a shoehorn to slide on a tight shoe.
622 L3.60 software - Slow Channel Changing?
Adding televisions
