Dry erase board
JimMcC
580
Screen
It would hotspot because it's too glossy. What size screen are you looking for? There are numerous cheap DIY options.
JimMcC
580
Screen
Shadowwalker, which projector do you have? Do you want a white or gray screen? One very popular DIY screen is to use blackout cloth(it's white) from any fabric store, and staple it to a wooden frame you build(about $40 total). Or you can paint a sheet of Medium Density Fiberboard, $30 including paint(This is what I did for my screen). Or you can buy a 4'X8' sheet of Parkland Plastic wall panel, or Doable Board and hang it as is(they're both white). But they're hard to hang because they're thin. There's a lot of info at Avsforum.com in the DIY Screen section.
iammike
953
Roanoke,VA
Sounds like you did a lot of the same reading I did before building my screen. I used a 4 x 8 sheet of quarter inch hardboard for mine, and painted. I haven't kept up with Avsforum lately, but at the time I did mine Glidden Misty Evening flat was the preferred paint. It's a very light gray color, sold at Home Depot. I also built a small 50" screen out of the same stuff to take on vacation.
jayn_j
Press On Regardless
11,286
4,773
Sheboygan, WI
I have used both Whitboards and SmartBoards. LOTS of glare...but they work.
I use whiteboards a lot when doing travelling presentations. The trick is to have the whiteboard over on the far side of the presentation room and then angle the projector away from the audience. That way the glare doesn't reflect back. I am still looking for a practical portable screen that goes on an airplane.
randomq
Mar 5, 2006
24
I've used one temporarily and it will hot-spot. However, the pricture is very bright, and you can always arrange it so the hot-spot will not be visible to the viewers, by adjusting the vertical position of the projector and the height of the screen.
jayn_j
Press On Regardless
11,286
4,773
Sheboygan, WI
What is you main need to be considered "practical?
Da-Lite Portable and Tripod Screens
http://www.dalite.com/products/index.php?cID=19
NexTag Listing (of one)
http://www.nextag.com/DA-LITE-Dalite-DaLite-55199774/prices-html?nxtg=2dae0a1c0530-7E92FAE53E678FE7
The ones you cited would be good for a situation where you were working a local area by car, or for a tradeshow booth. However, they would be too bulky for presenting in a working group or customer where you were doing a lot of air travel. However, the following one from the da-lite site holds some promise.
http://www.dalite.com/products/product.php?cID=11&pID=334
Thanks for the pointer. I'll look into that one.
charper1
Bourbon Tester
18,442
6
I'm Nationwide
Thats exactly why I asked what your particular needs were, while tossing out some ideas in the mean time. As it seems you already are finding what you might want; Good luck.
Sharp AQUOS 37" question
Virtual Surround Sound
