I am looking into switching from TWC internet to FiOs internet, and eventually TV.  I know FiOs gives you a modem/WiFi router in one device.  Because of this are you able to hook up a separate external WiFi router?
			DodgerKing said:I am looking into switching from TWC internet to FiOs internet, and eventually TV. I know FiOs gives you a modem/WiFi router in one device. Because of this are you able to hook up a separate external WiFi router?
Yes can do that but it is not necessary. I have replaced the Actiontec router supplied by Verizon with an Asus RT-N16 flashed with DD-WRT. You have to tell the Actiontec or other Verizon supplied router to release the IP. Shut it down immediately and then you can start up the new router. You can find the details on DSLReports.I want to use their router as a modem only and use my router as the main WiFi and Router for my home network. Is this possible?
Thanks for the info.Yes can do that but it is not necessary. I have replaced the Actiontec router supplied by Verizon with an Asus RT-N16 flashed with DD-WRT. You have to tell the Actiontec or other Verizon supplied router to release the IP. Shut it down immediately and then you can start up the new router. You can find the details on DSLReports.
That link mentions the issue that I did: the STBs need the FIOS router connected to the ONT to provide the cable bridge for their network connections. It also warned about having too many DHCP servers on your LAN.Voyager6 said:Yes can do that but it is not necessary. I have replaced the Actiontec router supplied by Verizon with an Asus RT-N16 flashed with DD-WRT. You have to tell the Actiontec or other Verizon supplied router to release the IP. Shut it down immediately and then you can start up the new router. You can find the details on DSLReports.
If you are getting the Fios TV and/or Phone then the Verizon router must be connected. Fios internet only does not require the Verizon router.That link mentions the issue that I did: the STBs need the FIOS router connected to the ONT to provide the cable bridge for their network connections. It also warned about having too many DHCP servers on your LAN.
What is ONT?
