Starlink Router question
TRG
The Great American Southwest
8,678
18,440
Albuquerque, NM
I set up a music server for my brother a few years ago. It's basically a small headless computer but it needs to have a DHCP IP address reserved for it in the router settings. This was easy to do in his DSL router. He's switching to Starlink now and I was wondering if these setting are easily accessible in the Starlink router. I'm pretty sure he will be getting the latest V5 router.
If you can't get into the router to reserve an IP address just don't use DHCP on the device that needs connected and assign it to a specific IP address in the network settings.
Reactions: harshness
They are not. Your best bet is to set up a third-party router, attached to the Starlink for your server, that you can get into, like a Linksys, etc
Reactions: Foxbat
…it needs to have a DHCP IP address reserved for it in the router settings. This was easy to do in his DSL router. He's switching to Starlink now and I was wondering if these setting are easily accessible in the Starlink router. I'm pretty sure he will be getting the latest V5 router.
The Starlink V5 Install Kit I just got comes with the Mini Router. It is pretty limited in what it can do. For example, it can provide only one IP subnet at a time, no Guest Network, but it does support the pass-thru to a third-party Router. You can also split the Wi-Fi into separate 5 GHz & 2.4 GHz SSIDs to help some IoT devices that don't support 5 GHz bands to work.
The larger Starlink Router that still comes with the V4 Kit does support a Guest Network with separate IPv4 Subnet, but it's $120 from Starlink. And it still won't do DHCP Reservations.
If you can restrict the DHCP address space to assign addresses to one end of the subnet (i.e. x.x.x.50+), you can manually assign the IP address on pretty much any operating system. This is a default behavior on several popular routers. As the Router Mini only supports 235 devices, I expect that's already done.
Another option is to use a router that supports PoE to power the antenna. This article discusses that option (under PoE Power heading):
Reactions: Foxbat
Now that I've had the v5 kit with the Mini Router, it's not as bad as I first thought. Yes, no DHCP reservations, but you can set up multiple SSIDs that have separate IPv4 subnets, and like the big brother, you can select from 192.168.x.0/24 or 10.x.0.0/16 (where "x" is 1-4).
You can also split a subnet and have different SSIDs for the 5 GHz and 2.4 GHz channels to handle some IoT devices. I haven't discovered what subnet the 2nd NIC on the router assigns, I'm guessing it's the first subnet.
Reactions: HipKat
LFP Power Supplies for UPS
Laptop Shutting Off When On Battery?
