False, Constant Meter Signal
bajadock
Nov 17, 2009
12
Pacific Ocean
Eqpt is Directv hr24 dvr, swm power unit, swm3 dish. Have done at least 12 sat points, half without sat siignal meter. Yes, correct cables going from swm power unit to rcvr and LNB. Setup screen is swm 3 dish, swm and dual tuners. 10 foot cable run from lnb to rcvr.
1. Setup dish same as neighbor 200 yds away. No sat 101 signals(all 0),but pegged sat finder meter. Made usual tiny changes with no success. Turned dish approx 30 degrees to check LNB connection and meter was still pegged. Meter stayed pegged with wide sweeps.
2. Rechecked all connections with my co-pilot also checking.
3. Changed out all cables with cables from another working setup.
4. Changed to non swm dish with matching rcvr...101 lit up hi 80s to 100, NO PROB!
5. Took swm lnb to neighbor's house and installed....NO PROB!
What could be wrong? And why am I getting constant false positive meter(tested meter at neighbor's)???
Thx
stardust3
8,730
7,187
If meter is analog you could be on the wrong bird.
bajadock
Nov 17, 2009
12
Pacific Ocean
Good ideas, but have been using this analog meter for years. As mentioned, tested meter at another site with no problems yesterday. Cheers
stardust3
8,730
7,187
Reread your post. I seen this happen before. Resetting the receiver has worked in the past for me.
stardust3
8,730
7,187
Yeah adjusting the attenuation on an analog meter is key also.
On a side note when installing jupiter systems we use an app on our smart phones to tune the dish via wifi. It's a shame neither dish or directv hasn't done something similar. It would make everybody's lives easier.
stardust3
8,730
7,187
Similar meter. Yup, turned it down. Still gave long sweep positive. Away from install site. Will try red 'panic' button.
Something else I'd try and you already may be doing. Use a 4 wire lnb and receiver power only (no swm or power inserter) to tune the dish. Once tuned swap out for the swm lnb and put power inserter back in line.
Jimbo
71,056
9,565
NW Ohio - Buckeye Country
Just got to thinking is the PI in the line when he's setting it up, that analog isn't gonna like the voltage from the PI.
bajadock
Nov 17, 2009
12
Pacific Ocean
Friend at install site has been traveling. Liked the lnb3 swap idea for dish point, then throw in swm setup. Supplier insisted no B Band converters needed on my HR24-100 receiver. Ouch, FAIL. Trying again tomorrow. cheers
stardust3
8,730
7,187
B band converters used to be a big deal. I know they're not needed in my dma anymore. It may also be that way everywhere, I'd say it's a safe bet to go with suppliers info.
Running out of ideas to tell you. May want to try holding your mouth a different way the next time you try. :) Persistence is key.
Need to change setup in receiver menu when using a 4 wire lnb. It won't automatically recognize that setup like it will a swm.
Confused person, on boxes and dish, GENIE vs Pre-GENIE
4K mini and HR44...Your take
