b-band converters have nothing to do with your DMA. If you don't have an SWM system you need b-band converters.
This all depends on what recvr/dish set up is required, designated area doesn't matter.Somethings changed, not sure when or the details. I'll make some calls tomorrow and find out. I know they're not being used anymore here.
IF your setting up a SWM dish, NO BBC's required (HR23 as well).
Non SWM requires BBC's.
Thats what I'm saying, what changed is the recvr used and the dish changed .... I think, depending how far back your talking, Before the SWM dishes came out you always used BBC's, once the SWM stuff started coming out, the BBC's were no longer required.I understand what you guys are saying. That is how it was, but at some point not sure when, that changed. The op's supplier said the same thing. I'll find out and post back.
Supplier insisted no B Band converters needed on my HR24-100 receiver.
BBCs are not being used not because of where you live but because DirecTV is no longer installing legacy set ups for new customer any longer. But if you are an existing customer with a legacy set up and you have an HR24, you would need a pair of BBCs regardless where you live in the country.I'm talking about the newer receivers working with a 4 wire non swm lnb. The genie will only work with swm lnb setup, the others can go either way.
So, is it up and running now ?Did some checking today and am here to say I stand corrected. The newer receivers on a legacy 4 wire lnb do require b-bands. The only exception is on the hr-23 & h-23 boxes, they do not require them. That may be where I got this notion from. Sorry for the confusion. Cheers
Yup, Sorry ....Jimbo do you have me mixed up with the op?
I haven't installed any hr-23 or h-23 boxes in a long time. Almost everything is genie with swm anymore.
