Fortec LT Ultra losing settings
CbandLover
161
I have only now noticed this problem because I just completed my pole mount/motor/dish install and have been messing with it all day. I have several sats programmed in and scanned with channels. All I have is a motor with a Primestar dish with the original standard lnb on it. Nothing else. Why when I add a new satellite or delete, say, SBS 6 and powerscan it again, does the FTLUltra screw up the LNB type, disables USALS, and sometimes adds in Disecq port numbers for almost every satellite? I have to go back thru every one of the sats and change all the settings back! This is driving me NUTS! What am I doing wrong?
Other than this problem, the USALS, motor/dish, and receiver are bang-on every satellite without hesitation. Awesome.
Usually that's caused by having TOO many transponders loaded on your receiver.
If you go through each satellite and delete all but one transponder that should fix it!
You will NOT lose any of your stored channels :)
Thanks Pete for the quick reply. I will certainly try that fix instead of pulling my hair out. Thanks much.
