G-10r
firebird1234
Nov 5, 2006
6
im runing a 76 cm winegard with a quad lnb invacom. standing in back of dish where adjusting screw's are which way do i go with dish. or i was told that invacom quad wount work others say yes. 2 new lnbs later im still stuck. i have bought a fortec star universal lnb an invacom snh-031 and a megasat ms 1075 and nothing. so im guessing that the signal is that much more weaker then 119 that i cant.....? a true helping hand would be nice......any 1 need a lnb
The Invacom quad will work for G10. Need to use the "L" side of the LNB :)
LInear satellite (like G10) are lower powered so it takes a little more precision tuning to pick them up. But very doable and the stuff on G10 is really good :)
g-10
What channels are you trying to get?
Send me a PM!
i guess this is a pm took a while to find out how. as much as i tried i cant or know how do get g-10.im hitting 119 so behind dish where the set screws are its upper left from 119.....im trying to get what ever is on g-10
im using a birdog but for signal im geting strong red hit accross. quality nothing.on birdog meter it had 2 setings among other things .so i get more on kv then kh . i tried looking it up on the site but didnt come accross the info.........
Give us you zip code and we can give you all the angles needed from your area.
If you are still using the Invacom QPH-031 make sure to set the L.O. (LNB Freq.) on the Linear output to 10750
zip is 07204 yes im still using quad ..........will the snh-031 work for this single plug im guessing a tree branch will kill the signal........
Anything blocking the signal will cause problems, think of it like a flashlight beam, the dish must have a clear view of the satellite in the sky.
If you use the SNH-031 change the L.O. (LNB Freq.) to 9750-10600
Code:
Roselle Park, NJ 07204
         Latitude 40° 39.906'N Longitude 74° 16.020'W
                       Sat Name Sat Lng Az(t) Az(m)   El  Skew
                       Amos 1/2    4.0W 103.2 117.6  6.2 -47.6
                Atlantic Bird 3    5.0W 103.9 118.3  6.9 -47.4
                Nilesat 101/102    7.0W 105.3 119.7  8.4 -47.0
     Telecom 2D/Atlantic Bird 2    8.0W 106.0 120.4  9.2 -46.8
                     Express A3   11.0W 108.2 122.6 11.4 -46.1
                 (C) Express A4   14.0W 110.4 124.8 13.6 -45.3
                     Telstar 12   15.0W 111.2 125.6 14.4 -45.0
                   Intelsat 901   18.0W 113.5 127.9 16.6 -44.1
                          NSS 7   22.0W 116.8 131.2 19.5 -42.6
                   Intelsat 905   24.5W 118.9 133.3 21.2 -41.6
                   Intelsat 907   27.5W 121.5 135.9 23.3 -40.3
                  Hispasat 1C/D   30.0W 123.8 138.2 25.0 -39.1
                   Intelsat 801   31.5W 125.2 139.6 26.0 -38.3
                   Intelsat 903   34.5W 128.1 142.5 28.0 -36.7
                     (C) AMC 12   37.5W 131.1 145.5 29.9 -34.9
                        NSS 806   40.5W 134.3 148.7 31.7 -32.9
                      Pas 3R/6B   43.0W 137.0 151.4 33.1 -31.1
                         Pas 1R   45.0W 139.3 153.7 34.2 -29.6
               (C) Intelsat 705   50.0W 145.3 159.7 36.8 -25.6
                   Intelsat 707   53.0W 149.2 163.6 38.1 -22.9
               (C) Intelsat 805   55.5W 152.5 166.9 39.2 -20.5
                          Pas 9   58.0W 155.9 170.3 40.1 -18.1
                       Amazonas   61.0W 160.1 174.5 41.0 -15.0
                     EchoStar 3   61.5W 160.8 175.2 41.2 -14.4
                      Rainbow 1   61.5W 160.8 175.2 41.2 -14.4
               Estrela do Sul 1   63.0W 163.0 177.4 41.6 -12.8
               (C) Brasilsat B2   65.0W 165.9 180.4 42.0 -10.6
               (C) Brasilsat B1   70.0W 173.5 187.9 42.8  -5.0
                       Nahuel 1   72.0W 176.5 190.9 42.9  -2.6
                      DirecTV 1   72.5W 177.3 191.7 42.9  -2.1
                          AMC 6   72.0W 176.5 190.9 42.9  -2.6
                          SBS 6   74.0W 179.6 194.0 43.0  -0.3
                 Echostar/G4R 4   77.0W 184.2 198.6 42.9   3.2
                          AMC 5   79.0W 187.2 201.6 42.7   5.5
                      Nimiq 2/3   82.0W 191.8 206.2 42.3   8.9
                          AMC-9   83.0W 193.3 207.7 42.1  10.0
                (C)Brasilsat B3   84.0W 194.7 209.2 41.9  11.1
                          AMC 2   85.0W 196.2 210.6 41.7  12.2
                          AMC 3   87.0W 199.1 213.5 41.2  14.4
                           IA-8   89.0W 202.0 216.4 40.6  16.5
                      Galaxy 11   91.0W 204.8 219.2 39.9  18.5
                     Nimiq 1/4i   91.0W 204.8 219.2 39.9  18.5
                (C)Brasilsat B4   92.0W 206.1 220.5 39.6  19.5
                           IA-6   93.0W 207.5 221.9 39.2  20.5
                      Galaxy 3C   95.0W 210.2 224.6 38.4  22.4
                           IA-5   97.0W 212.7 227.1 37.5  24.2
                      Galaxy 16   99.0W 215.3 229.7 36.6  26.0
                     Spaceway 2   99.2W 215.5 229.9 36.5  26.1
                DirecTV 1R/4S/8  101.0W 217.7 232.1 35.6  27.6
                          AMC 4  101.0W 217.7 232.1 35.6  27.6
                     Spaceway 1  103.0W 220.1 234.5 34.5  29.2
                          AMC 1  103.0W 220.1 234.5 34.5  29.2
                         AMC 15  105.0W 222.4 236.8 33.4  30.7
                       Anik F1R  107.3W 224.9 239.3 32.1  32.4
                     (C) AnikF1  107.3W 224.9 239.3 32.1  32.4
                      DirecTV 5  109.5W 227.3 241.7 30.8  33.9
                  EchoStar 8/10  110.0W 227.8 242.2 30.5  34.2
                        Anik F2  111.1W 229.0 243.4 29.8  34.9
                       SatMex 6  113.0W 230.9 245.3 28.6  36.1
                  Solidaridad 2  114.9W 232.8 247.2 27.4  37.2
                       SatMex 5  116.8W 234.6 249.0 26.2  38.2
                         AMC-16  119.0W 236.7 251.1 24.7  39.3
                     DirecTV 7s  119.0W 236.7 251.1 24.7  39.3
                     EchoStar 7  119.0W 236.7 251.1 24.7  39.3
          EchoStar 9/Telstar 13  121.0W 238.5 252.9 23.3  40.3
                     Galaxy 10R  123.0W 240.2 254.6 22.0  41.2
                  (C) Galaxy 14  125.0W 242.0 256.4 20.5  42.0
                   Galaxy 13/H1  127.0W 243.6 258.0 19.1  42.8
 Intelsat Americas 7/Echostar 5  129.0W 245.3 259.7 17.7  43.5
                     (C) AMC 11  131.0W 246.9 261.3 16.2  44.2
                  (C) Galaxy 15  133.0W 248.4 262.8 14.8  44.9
                     (C) AMC 10  135.0W 249.9 264.3 13.3  45.4
                      (C) AMC 7  137.0W 251.4 265.8 11.8  46.0
                      (C) AMC 8  139.0W 252.9 267.3 10.3  46.5
                   EchoStar 1/2  148.0W 259.2 273.6  3.6  48.2
       Satellite Finder is (c) Copyright 2004, P. Lutus
thats a nice list thanks.........................changeing frequence meaning on my vs-ex right!!!!!....i will be happy if i get a meter reading in green...lol:)
KPOU Sold: Equity to Fisher
Satwork ST3618
