Galaxy 10R - TP 5 reception good - no TP1 reception
cebu22
51
Hi,
I'm able to receive Galaxy 10R programming on TP5. Unfortunately, I'm unable to receive any programming on Galaxy 10R on TP1. Is this a common problem? I'm using a 30" FORTEC dish, coolsat 4000 pro receiver, and a motor (USALS) - Boston area. If I attempt to peak the dish for Galaxy 10R - TP1 should I start with the azimuth or elevation angle. I'm concerned about
changing the dish's setting since all other satellite are being tracked successfully using USALS - maybe small changes in azimuth/elevation would be tolerable.
Thanks - I love this stuff
I have the same problem with mine
cebu22 said:
Hi,
If I make the setup peak on TP1 for Galaxy 10R, I won't able to track the arc right and some satellite I can't view. When I get all the satellites, I won't able to get enough signal on TP1 for Galaxy 10R
11719 (TP1) is lower than the rest due to a Dish Network satellite at 121 (there is a 11720 V on 121 too which goofs up the G10 one)
try to tweak it...nudge the dish one click E or W on the receiver and see if that works. Otherwise, you might have to tweak it by hand.
NFL on FTA?
FTA newbe...Hows this setup look? And a few Q's..
