H20 + Hr 10-250
cdr2000
15
My HR10-250 HD DVR was just installed. The picture quality is much worse than the H 20 receiver I was using. I still own the H 20 and wondered if both receivers could be connected simultaneously to my TV. I could connect one via components and the other via HDMI. This would allow me to switch back and forth. Could I split the signal for this purpose? If so, would the network cards preclude this setup? Any help you can provide would be appreciated.
Yes...
I had this setup for about 8 months...
You can't "split" the signal.. you will need run a 3rd SAT line, or only use the HR10-250 with one line.
Thanks for the reply. Which hr10-250 line to use? Does the 2nd line go into the h20?
If you only have TWO lines available from your dish..
Then one to INPUT 1 of the HR10-250 and one to the H20
If you can run a third line... then TWO to the HR10-250 and one to the H20...
That way you could use both to their fullest...
Or you can just save your pennies and get the HR20 :D
Thanks for the help. What would be the effect on the HR10-250 and the H20 with only one line each?
The only effect woudl be that the HR10-250 would only be able to record 1 item at a time (instead of 2)
Sad day for me... No more DTV...
Episode III - As the Satellite World Turns
