HR44 rebooted overnight?
Former member 209992
1,703
569
Hello again, haven't posted here in a while.
This morning, around 6:30am, I woke up and found the front panel lights on my HR44 on (I leave it off all the time as it is co-located with one of my Geminis).
Immediately thinking that either a reboot or power outage occurred, I checked the software version, and found that it's still the same release that was sent out last month.
I then ruled out a power outage by checking the clocks on my appliances and seeing that they're still correct (they reset when there's an outage, somewhat similar to the "blinking 12" on VCRs).
I then confirmed a reboot by checking the Upcoming Recordings (fka To-Do List) and seeing that the number was much lower than before (it always resets after a reboot).
I am definitely guessing what happened (and it may very well be actually what happened) is that the "Reset Required" prompt may have come up sometime overnight, and it eventually timed out and rebooted automatically. IIRC that prompt comes up when new software "plugins" have to be installed.
Would like to hear your thoughts, especially since I probably haven't talked to some of you reading this in a while (was a former CE member, left almost a year ago).
Thank you all in advance!
My HR54 blue light is on this morning. I think you ae right about the plugins. They are tweaking things in the customer National release. What version does your HR44 Genie have now? I think you are probably on the same varsion as the CE group today.
No More DIRECTV AEP1 Remotes
Directv Gemini Receiver - C71KWX Question
