Has any tried using a SuperDish in place of a Dish 1K for better 129 performance?
Paradox-SJ
1,636
San Jose, California
Has anyone tried using a SuperDish in place of a Dish 1K for better 129 performance?
With the poor performance of 129 on the Dish 1K I was wondering if anyone has tried using the large SuperDish instead.
There should be some gain due to its larger size just not sure how much.
Cheers-
Could work if you modified the LNBF bracket. The super dish only come in 105 and 121 flavors and the 121 would be the closest, but the 121 is still 8 degrees from from the 129 so the bracket would need to be altered! How? I dunno.
Hi,
I added 129 onto my 121 Superdish and I get almost as good of a signal on 129 as I get on 119. The extra LNB is just tied on with wire ties for now. I will build a proper mounting bracket when it warms up. I am in Wisconsin if that makes any difference. Check out the thread below for more info on adding 129 to a Superdish...
http://www.satelliteguys.us/showthread.php?t=36979
Good Luck,
Bruce
The 121 LNB will NOT work for 129. It's the wrong type.
However, you could point the 119 LNB of the 121 SD to 129 and get good results.
I dont mean using the SuperDish LNB's but as I said using the SuperDish. Will the bracket from a D1k (W bracket) work on the SD arm or at least can it be rigged too?
nah. If you are going to use the SD for 110/119/129/whatever FSS side you have, just slap the LNB to the side of the 119 or 121 and use a hoseclamp
I have the SD121 setup with a zip tied 129 lnb like Bruce mentioned above. Works great with an 80+ signal on 129 and around 100 on 110/119.
Anyone have any luck moving up an install?
622 ota antenna install help
