HDTV or HD projector? both $350!
fp? you mean front projection?
i dont know how good of item it would be, but since im buying it straight from the facotry, im sure its alot cheaper.
I know it's very tempting at that price, but DON'T BUY IT. I suggest you save a couple hundred more dollars, and buy a real 720p HD projector. Yes, there are new 720p projectors for about $600. If you don't want to spend more than $350, buy the TV. I love my projector, but that's a piece of junk.
I have to agree.
I would get neither honestly. If money were the issue, I would save a little longer and get a quality set.
You can spend a few more bucks and get the 720p vizio from wal mart as well.
Another hundered and get the 1080p version.
I dont have a vizio, but from what I have seen they are decent sets for the price.
Never heard of Viore, which generally means stay away. It may do HD decently enough, but I would imagine it would blow on SD. Of course, again I have never seen one, so it may be ok.
I would really stay away from that particular FP.
Keep looking, there are decent deals on good equipment.
Any more questions, just ask
also i was wondering if that would handle SD better then a regualr tv.
Generally speaking, SD will look worse on most HD sets than the old regular tvs.
Some do a better job with this material than others, but it generally costs you.
I would have to be the second one to agree with you.
Also if you look at the specs it is not a HD projector. It only does 1024X768 which is not HD.
ok i see good brand, like 3m and sharp. hd projectors selling on ebay for around $250-$300.
The reason i wanted to shy away from them is, when those bulbs burn out, there about $250.
Those budget $350 projectors take a $30 halogen bulb.
So would a good brand projector like 3m or sharp outlast the budget one?
its on the ebay link i posted, it takes a standard halogen lightbulb instead of a $200+ qaurtz lamp
Can you post a link to one of the replacement bulbs. I have never heard of a projector only taking a $30 halogen bulb.
Another reason I would stay clear of it. If it sounds too good to be true (to be fair most of that link doesnt based on specs), it usually is
I would imagine you give up some brightness and contrast with that. Just a guess
Keep in mind that if you go with a front projector you will also need to invest in a good screen (which is not cheap), installation, perhaps longer cables. You will also need the total darkness in the viewing room. So, if your budget is under $500 or so, FP is probably not such a good idea.
