Help installing Dishnetwork
zkrak
3
Due to geographic location, I have 2 Channel Master 1.8m antenna. I have acquire 2 DP Twin LNB and DP receiver vp 211 and DP 34. Are the steps below correct:
*Install DP Twin LNB on antenna and point each antenna to 119 & 110 respectiveley
* Connect a branch from each LNB to the DP 34 with 119 on port 1
* Connect the receivers to the DP 34
Adapter
Do I need a DP Pro adapter with the DP 34 and VIP22k + VIP 211k?
A DP "TWIN" LNB is the wrong LNB if you are going to aim one Channel Master at 110 and the other at 119. You need either a DP dual LNB or if you can find it a DP single LNB. One cable from each dish is run to the input on the DP34 switch that will provide 4 outputs for receivers. Dish Pro adapters are for use on Legacy receivers connected to Dish Pro systems.
Problem with Skip on my 722
622 rebooting on timer edits
