Help With Aligning Dish
Gray1
308
St. Louis, Missouri
Would somebody be kind enough to check and see if this is right. I've never done this before so be kind. :)
I will be going with an SG-2100 motor and probably a Winegard (2076) Dish.
Zip code is 63670.
Motor Angle 38.0
Dish Angle 23.8
If I read the Sadoun Chart right, I should not have to adjust for magnetic (true) south because the "0" line runs right over me. Is this right?
The closest South Satellite is either IA8 or G11? If this is right which would be the best one to "tune" first?
You guys are the best and have already helped me so much.
Allen
You're right between 91w (G-11) and 89w (IA-8), a degree off from each. If you use USALS to setup your dish, it will accurately move your motor to either.
No magnetic deviation for your azimuth :)
G11 is slightly closer to your TRUE south position.........
I would try to FIND and store G11 @ 91ºw WITHOUT the motor first, only then would I add the motor.......
The below elevations are WITHOUT the motor.
Code:
                  Lake Forest Esta, MO 63670
          Latitude 37° 57.024'N Longitude 90° 5.760'W
                       Sat Name Sat Lng Az(t) Az(m)   El  Skew
                       Amos 1/2    4.0W  92.4  92.9 -5.6 -52.0
                Atlantic Bird 3    5.0W  93.0  93.5 -4.8 -51.9
                Nilesat 101/102    7.0W  94.3  94.8 -3.2 -51.8
     Telecom 2D/Atlantic Bird 2    8.0W  94.9  95.4 -2.5 -51.8
                     Express A3   11.0W  96.8  97.3 -0.1 -51.5
                 (C) Express A4   14.0W  98.7  99.2  2.2 -51.2
                     Telstar 12   15.0W  99.3  99.8  3.0 -51.1
                   Intelsat 901   18.0W 101.2 101.8  5.4 -50.7
                          NSS 7   22.0W 103.9 104.4  8.5 -50.0
                   Intelsat 905   24.5W 105.6 106.1 10.5 -49.4
                   Intelsat 907   27.5W 107.7 108.2 12.8 -48.7
                  Hispasat 1C/D   30.0W 109.5 110.0 14.7 -48.0
                   Intelsat 801   31.5W 110.6 111.1 15.9 -47.6
                   Intelsat 903   34.5W 112.8 113.4 18.2 -46.6
                     (C) AMC 12   37.5W 115.2 115.7 20.5 -45.5
                        NSS 806   40.5W 117.6 118.1 22.7 -44.3
                      Pas 3R/6B   43.0W 119.8 120.3 24.6 -43.2
                         Pas 1R   45.0W 121.5 122.0 26.0 -42.2
               (C) Intelsat 705   50.0W 126.1 126.7 29.5 -39.6
                   Intelsat 707   53.0W 129.1 129.6 31.6 -37.7
               (C) Intelsat 805   55.5W 131.7 132.2 33.2 -36.1
                          Pas 9   58.0W 134.4 135.0 34.8 -34.3
                       Amazonas   61.0W 137.9 138.4 36.6 -31.9
                     EchoStar 3   61.5W 138.4 139.0 36.9 -31.5
                      Rainbow 1   61.5W 138.4 139.0 36.9 -31.5
               Estrela do Sul 1   63.0W 140.2 140.8 37.7 -30.3
               (C) Brasilsat B2   65.0W 142.7 143.2 38.8 -28.5
               (C) Brasilsat B1   70.0W 149.3 149.8 41.2 -23.8
                       Nahuel 1   72.0W 152.0 152.5 42.1 -21.7
                      DirecTV 1   72.5W 152.7 153.2 42.3 -21.2
                          AMC 6   72.0W 152.0 152.5 42.1 -21.7
                          SBS 6   74.0W 154.9 155.4 42.9 -19.6
                 Echostar/G4R 4   77.0W 159.3 159.8 43.9 -16.2
                          AMC 5   79.0W 162.3 162.8 44.5 -13.9
                      Nimiq 2/3   82.0W 167.0 167.5 45.2 -10.2
                          AMC-9   83.0W 168.6 169.1 45.4  -9.0
                (C)Brasilsat B3   84.0W 170.1 170.7 45.6  -7.8
                          AMC 2   85.0W 171.7 172.3 45.7  -6.5
                          AMC 3   87.0W 175.0 175.5 45.9  -4.0
                           IA-8   89.0W 178.2 178.7 46.0  -1.4
                      Galaxy 11   91.0W 181.5 182.0 46.0   1.2
                     Nimiq 1/4i   91.0W 181.5 182.0 46.0   1.2
                (C)Brasilsat B4   92.0W 183.1 183.6 46.0   2.4
                           IA-6   93.0W 184.7 185.2 45.9   3.7
                      Galaxy 3C   95.0W 187.9 188.5 45.7   6.3
                           IA-5   97.0W 191.1 191.7 45.4   8.8
                      Galaxy 16   99.0W 194.3 194.8 45.0  11.2
                     Spaceway 2   99.2W 194.6 195.1 45.0  11.5
                DirecTV 1R/4S/8  101.0W 197.4 197.9 44.6  13.6
                          AMC 4  101.0W 197.4 197.9 44.6  13.6
                     Spaceway 1  103.0W 200.4 200.9 44.0  16.0
                          AMC 1  103.0W 200.4 200.9 44.0  16.0
                         AMC 15  105.0W 203.4 203.9 43.3  18.3
                       Anik F1R  107.3W 206.7 207.2 42.5  20.8
                     (C) AnikF1  107.3W 206.7 207.2 42.5  20.8
                      DirecTV 5  109.5W 209.8 210.3 41.6  23.1
                  EchoStar 8/10  110.0W 210.5 211.0 41.3  23.6
                        Anik F2  111.1W 212.0 212.5 40.8  24.7
                       SatMex 6  113.0W 214.5 215.0 39.9  26.5
                  Solidaridad 2  114.9W 216.9 217.4 39.0  28.3
                       SatMex 5  116.8W 219.3 219.8 37.9  30.0
                         AMC-16  119.0W 221.9 222.4 36.7  31.8
                     DirecTV 7s  119.0W 221.9 222.4 36.7  31.8
                     EchoStar 7  119.0W 221.9 222.4 36.7  31.8
          EchoStar 9/Telstar 13  121.0W 224.2 224.7 35.5  33.4
                     Galaxy 10R  123.0W 226.5 227.0 34.3  34.9
                  (C) Galaxy 14  125.0W 228.6 229.1 33.0  36.3
                   Galaxy 13/H1  127.0W 230.7 231.2 31.7  37.6
 Intelsat Americas 7/Echostar 5  129.0W 232.7 233.2 30.4  38.8
                     (C) AMC 11  131.0W 234.6 235.1 29.0  40.0
                  (C) Galaxy 15  133.0W 236.5 237.0 27.6  41.1
                     (C) AMC 10  135.0W 238.3 238.8 26.1  42.1
                      (C) AMC 7  137.0W 240.1 240.6 24.7  43.1
                      (C) AMC 8  139.0W 241.8 242.3 23.2  44.0
                   EchoStar 1/2  148.0W 248.9 249.4 16.4  47.4
       Satellite Finder is (c) Copyright 2004, P. Lutus
The Motor elevation = 52º (One side is Lat. one side ELEV.)
The dish on motor elevation = 24º
