Meaning letting one go to waste, that's funny Techno!Keep me posted if you spot someone not using their BUD properly.
Meaning letting one go to waste, that's funny Techno!![]()
Plus, I've never understood the need for a reversed polarity LNB on a T-90, T-55, or any toroidal dish for that matter. Could someone explain?
Jerry
Where did you get the parts to make your setup?
rdel
Good job Jerry
Keep in mind the off center LNBFs will need to be raised or lowered relative to the center LNBF. It could be a few inches lower/higher. That depends on the skew required for your location. Also, using a 90CM+ dish is prefered for such setup.
Good luck and keep us posted.
i was thinking about the raised and lowered part too. guess the shape of the toroidal dish does this ( where we can't see it) so some satellites might need to be raised or lowered to aquire best signal.
Jerry
I really liked the looks of that one , its very professonal looking. did you set it up to use the toroidal lnb holders??
thanks
this sounds like you buying them & fabricating them also. hopefully your not incurring too much expense.Have about every multifeed bracket I could find, and ended up using the holders from a cheap multifeed on ebay. They allow for up and down adjustment.
