Hopper instalation
ebdiel
3
I'm trying to setup a hopper with two joys, but I'm getting stock in acquire signal. Does the hopper need a special lnb, I had a dish pro plus dual lnb and I'm connecting to a dp34. Later I connect to the solo node. That's correct??? Please I need help
Hopper doesn't work with DP switches. Going to need a DPP33 or a DPP44, or better yet just get a 1000.2 or a 1000.4.
As stated above, best to pick up an HD dish. If you want to use your DPP Dual though, just leave the dp34 out of the equation and connect it directly to your Solo Node.
Which sats are you trying to pick up?
I live in Puerto Rico and I'm setting up the 119/110. But I connect directly from the lnb and I get in turner 1 and 2 signal from 119 and in turner 3 signal from 110.
So you're using two DP Duals? If so, you'll need a DPP33 or a DPP44 to get both sats on all three tuners. You'll need a feed from each LNB going into the switch and two feeds from the switch to the Solo Node.
Sent from my iPad 2 using Forum Runner
Any way to get more range on IR TV 2 remote?
Dish falling behind in HD
