HR20 - HDMI or Componet?
mkatts
467
In my situation, HR20 and a 42" Samsung Plasma, There is zero difference betweem component and HDMI. I would get the Component first, if you are happy fine, if you want to try to improve it then check out monoprice.com. you can get a $5 HDMI cable. For sure DO NOT but the rediculous $100+ HDMI cables from the big guys.
Jimzo
46
Evanston, IL
I agree. There is very little that is more ridiculous than $100+ for a for an 18 inch HDMI cable. From a curiosity standpoint, it is probably worth getting a monoprice HDMI cable to determine whether or not you can tell the difference on your set.
Jim
ChrisClearman
86
i've never seen a difference on ANY broadcast (cable/sat) using HDMI or component. I do see some differences with DVD players.
So I reco to use your HDMI for other components first. If you have one left over for sat, go for it.
cheebs
222
I have both connected to my Optoma RD50 DLP 50-inch RPTV. I actually CAN tell a difference between the component and HDMI outputs, although it's very (VERY) small. There's better color saturation, and less "rainbow effect." I can see no difference as far as resolution goes.
texasbrit
Cutting Edge
Apr 12, 2006
3,656
365
Usually this is just because the inputs are not calibrated correctly. Some people see better results on component, but again if you had a complete system calibration you probably would not see any difference.
bonscott87
925
Only way to know is to try it yourself. Every TV is different and all of our eyes are different. I'd say most people can't tell the difference but it really depends on your TV and what you feel looks better.
lou_do
957
Central Maine
But all HDTV and satellite receiver manuals say for the best quality picture use the HDMI output. I wonder why they state that. Maybe the difference can be seen on a scope, but not by the human eye!!
jpn
756
Generally, it's the analog-vs-digital discussion. There may be some installations where appliances, computers, electrical-fields, or large unshielded-speakers nearby might induce some interference on the component video cables. An HDMI at the same installation would probably be immune, since the D-A conversion is done in the tv.
texasbrit
Cutting Edge
Apr 12, 2006
3,656
365
I think you are correct. I have seen posts where there was obvious induced interference in component cables. But I've also seen post about "sparklies" with HDMI which seem to be induced interference also And HDMI seems to run into problems on long cable runs (needs equalization) before component does.
Ratara
Jan 29, 2007
19
Personally, I have never seen a difference between using component cables and HDMI.
I think that the broadcasters want you to use HDMI because they can enforce Digital Rights Management (DRM) over HDMI and cannot enforce that over component cables.
Besides, all HDTV's are not compatible with the HDMI standard the H20-100 uses. You get a guaranteed picture using component cables.
iceturkee
DINFOS Trained Killer
7,392
146
daytona beach
where are you guys buying your hdmi cables? i bought a 15 ft cable for 25 bucks based on a recommendations from an avs forum member. i bought a second (6 ft) cable for 17 dollars from the same place. nice thick cables.....not anything junky!!!
raoul5788
Studebaker driver
Staff member
HERE TO HELP YOU!
33,150
18,477
Cheshire CT
The best I have used is www.svideo.com.
F. Y. I. for current H10 owners
How much worse can NBC-HD get ?
