Hughesnet? FTA dish
M-2 Hydra
45
12
Louisiana
I have a (Hughes net) dish that might be used for fta the lnb looked like it could be used for fta but I can’t find the lnb but it said Hughes data systems it is wider than a Sony or a dish network 500 dish any ideas?
I would save that for when you have more experience with FTA and then just use the reflector. I would pair that reflector with this:
Eagle Aspen 270 Dual Output Linear FTA LNBF (2 lot) | eBay
I would start with the GEOSATpro 90cm dish. You can grab that on eBay with LNBF for around a $100.
That lnb would mount up directly with it based on looks thanks will try it sometime do you of a good reciver that is cheap enough like 20-50 or 60 dollars?
I have a question about the lnb being dual lnb does that mean i can have 2 receivers hooked to it and 2 different channels a tv? Just wondering
Sent from my iPhone using Straight Talk or ViaSat
The Amiko is a very good receiver. If the top end of your budget is $60, I can also recommend the GTMedia V8 Nova (blue model). It has an excellent tuner and is a solid box for less than $50. I'm using it in the bedroom as an extra receiver.
Is there such as a satellite finder that can output to a tv that i can use as a reciver and then can be used as a satellite finder again or is this to expensive im just finding things out
Yes, several models output to a TV. Make sure that the output is HDMI 1080p and not just a composite 480i AV output.
An example is the Dr.HD 1000S+. I often use it as my receiver when camping. :cool:
Ok i will look around
For one
Sent from my iPhone 6 using Straight Talk or ViaSat
can i use a GTMEDIA v8 satellite finder with the GEOSAT pro 90cm dish because i may just get those for now or if you know of something better for me let me know
thanks for all the help!
