Hughesnet? FTA dish
M-2 Hydra
45
12
Louisiana
I have a (Hughes net) dish that might be used for fta the lnb looked like it could be used for fta but I can't find the lnb but it said Hughes data systems it is wider than a Sony or a dish network 500 dish any ideas?
I would save that for when you have more experience with FTA and then just use the reflector. I would pair that reflector with this:
Eagle Aspen 270 Dual Output Linear FTA LNBF (2 lot) | eBay
I would start with the GEOSATpro 90cm dish. You can grab that on eBay with LNBF for around a $100.
That lnb would mount up directly with it based on looks thanks will try it sometime do you of a good reciver that is cheap enough like 20-50 or 60 dollars?
I have a question about the lnb being dual lnb does that mean i can have 2 receivers hooked to it and 2 different channels a tv? Just wondering
Sent from my iPhone using Straight Talk or ViaSat
The Amiko is a very good receiver. If the top end of your budget is $60, I can also recommend the GTMedia V8 Nova (blue model). It has an excellent tuner and is a solid box for less than $50. I'm using it in the bedroom as an extra receiver.
Is there such as a satellite finder that can output to a tv that i can use as a reciver and then can be used as a satellite finder again or is this to expensive im just finding things out
Yes, several models output to a TV. Make sure that the output is HDMI 1080p and not just a composite 480i AV output.
An example is the Dr.HD 1000S+. I often use it as my receiver when camping. :cool:
Ok i will look around
For one
Sent from my iPhone 6 using Straight Talk or ViaSat
can i use a GTMEDIA v8 satellite finder with the GEOSAT pro 90cm dish because i may just get those for now or if you know of something better for me let me know
thanks for all the help!
Do you mean you want to use the V8 receiver as your satellite finder? Or are you talking about something different?
Titanium Satellite C1-PLL C-band LNBF Mod?
Need help choosing equipment
