i need help
overtaker
4
Hi I'm not sure if I post this in the right sub forum
I'm newb trying to setup my satelite dish
I have a problem trying to get the CCTV 1 in
AsiaSat 3S at 105.5°E - LyngSat
I can get most of the (free) tv that's below 500 freq, but never manage to get those above 10,000
anyone got any idea?
thx
receiver make: goldsat GSR-2600
LNB: 5150
Dish: no idea
I'm not sure what you mean by Transponder, if it means the channels, i can get almost all the non encrypted ones
from China Entertainment TV to Geo TV in that list
and my dish is static, can't move
AsiaSat 3s
Transponder 2H
Frequency: 3860
Polarity: H (horizontal)
Scan Rate: 26670
Maybe "below 500" was typo in first message.
If you mean "Below 5000" that makes sense.
Your 5150 LNB is for C Band Freq., they only have 4 digits
Do you see the CCTV1 towards the bottom of the Lyngsat page, it has 12511 listed as the Freq.
That is Ku Band(5 digits) You would need a Ku LNB to receive that.
I Googled your receiver and did not find much, so I can't tell you if it can handle the Ku frequency, but getting a Ku LNB is where you should probably start.
It looks to me like you get the C-band channels just fine, but now you're trying to get Ku band, around 12500 Mhz channels, so you need a different lnbf to get those higher channels. For you, a universal lnbf would allow you to get the transponders and channels above the 12000 MHZ point on that bird.
thanks, yeah it was a typo, my bad should be 5000
I can set the LNB to 10750 manually
but when i try to set for CCTV
freq: 12511
pol: H
scan rate: 4340
I couldn't receive anything
did I set the Ku band freq correctly? the option only has one field to enter LNB freq
you need a Universal LNB that goes from 10.7-12.75Ghz
The standards that we use here in North America don't go about 12.2Ghz
When you get the Universal it should be set for Universal 1 with LNB Freq of 9750/10600
I'm sorry but I don't understand how to "get the Universal" is it by setting the LNB freq to somewhere between 10.7-12.75GHZ ?
In the receiver menu there should be an option for a standard or Universal LNB
Set it to Universal if that is an option
...trying run FTA viesat X-treme (2000) and technician all sudden got stuck - we have strong signals (80-90% channels) but NO picture on TV unit nether scramble/skewed...just nothing...any help can be appreciate..regards Chris
...will try today, thank you for response...couldn't find how to go to new topic (???) - regards...Chris from Florida
HD Unit with PVR
fta question
