Inclinometer
sharpee
74
Bristol, PA
I want to get myself an inclinometer. I did a aearch on the major chain retailers.
No one had an "inclinometer" for sale. But I found an angle finder at Lowes.
Attahched is a pic of it : can someone let me know if this would help me out??
Sharpee
Greg Mueller said:
Yes, to a certain degree........:)
Greg,
What's your angle? :)
Sharpee.
You could also make one as shown here:
http://www.exploratorium.edu/math_explorer/tfl_howHigh_inclinometer.html
I seem to have much better luck estimating....Straight over my head is 90º,
half of that is 45º, half of that is 22.5º etc.
I've only messed with homemade inclinometers though. It's hard to keep them (edit) still. Maybe a manufactured one would make a world of difference.
(edit 2) I only use this to survey a potential site. It won't do much for actually setting up your dish (if that is what you were wanting).
Good luck.
Sharpee
Bought mine at harbor freight .
Wyr
I still have an inclinometer that I bought from Shawn Kenny, plus a lot of other stuff. I always looked forward to him bringing out the worst receiver of the week and smashing it with a slegehammer....and then of course there was yellow rain
Thanks for the trip down memory lane Greg
Thanks guys!!
I love this forum, been learning quite alot.
Now i need to learn how to use the angle finder!
Need to determine where to place the thing for proper EL alignment.
Sharpee
sharpee said:
Thanks guys!!
Sharpee
You can read some of my rambelings on angle finder at ;
hxxp://www.satelliteguys.us/showthread.php?t=62571&highlight=angle+finder
Replace the xx with tt for a working link .
I promise some if the info is reasonably accurate . :-)
Wyr
Sorry guys,
I should have stated I have an offset dish! :)
Dish is 35x30 inches with standard lnbf
Traxis 3500 receiver
Tried leveling the mount as plum as i could with a mind for the dish weight
I noticed my lnbf has a couple of small cracks on the round white cover with a very small pinhole!! Could my lnbf be water damaged?? I got it and the dish at a flee market.
The dish looks like its fine.
Thanks again!,
Sharpee
sharpee said:
Sorry guys,
Thanks again!,
Sharpee
Gently try removing the white cap . Some twist a little & pull straifgt off , kind of a bayonet setup .
If the insides look OK , put the white cap back on & seal it back up with some silicone or E6000 .
Remember to set the skew on the LNBF , when you re-install it on the mount .
If all else fails , linear polorized Ku LNBF's are moderatly priced .
Wyr
If Have Alot Of Snow And Your Signal Is Low
PAS9 From Los Angeles
