Installation Question
levibluewa
1,150
7
WA, OR, CA
Have 2 connections (2-hr10-100s)...1 in Living Room and 1 in BR. If I wanted to add another HD receiver off 1 of the existing connections, say BR, can I split the incoming cable before the B-Band Converter (1 in to 2 out) and then add the B-Band Converters before going into each receiver (then out to 2 separate tvs) OR do I need to go a different route?
Much thanks for your assistance.
You would need a multiswitch with the 4 lines ran into it from the dish. From there you can 8 outputs. 2 going to each of the HD DVRS which would then leave you 2 for the future. The BBC's are connected after the muliswich in each line of HD DVR usually at the receiver.
Drake and Josh in HD
5 LNB Pole Mount
