I'm going to be replacing my Dish 500+ with a 1000.2 and could use any tips you may have on cabling, tuning, if I should use a meter (if so .. which), etc.. Current setup up is typical ... 4 RG6 runs to 2 switches then on to two receivers/dual room setup on each. I bought a ViP722 which will be replacing both the current receivers. I understand the switches will no longer be needed and I should only need one RG6 feed to the 722. I guess one question would be, should I go ahead and connect all 4 LNB cables for possible later use or stick with just one going to the 722 ???
Thanks in advance !!!
Eric
Eric
