Just installed 2TB My Book Mirror (RAID-1) on 722k
navychop
Reunite Pangea! Stop overfishing Panthalassa!
63,220
32,028
Northern VA
Been moving all my shows to it and watching them from there; working great so far.
Good to hear. One problem with watching from the EHD, though: When it's over, you bounce back to the directory of recorded programs, rather than have the option to delete (which is how it works on the DVR). Then you have to scroll thru an often long list to find the program and delete it.
cditty
1,293
35
Northeast Louisiana
I wish they would eliminate the entire built in hard drive approach and put in a user removable slot, similar to the ps3. I only ask for that, because there isn't enough bandwidth on the USB 2.0 slot to do the 4 stream recording (like the 722K).
The hard drive has been the source of failure on almost all of my DVR's... It would be nice to just go buy another hard drive instead of going through the RMA process... I'm sure it would be cheaper for Dish as well... Maybe one day.
And thanks for all the info you have provided in this thread.
gadgtfreek
22,105
865
Lower Alabama
Ok, just finished the final experiment.
I turned it off, opened it, and then pulled Drive A. Reconnected the power, selected a program, and played it. This lets me know Drive B has my stuff on it correctly. I then pulled Drive B in the same manner, and then reconnected the power. I was able to then go in and find my programming with only Drive A in, and play them.
This tells me that both drives are identical, even to where the 722k had no idea, so RAID-1 is working GREAT :)
Some shots of the process below, and I included a shot of one of the drives and the guts of the my book mirror.
gadgtfreek
22,105
865
Lower Alabama
I did not check that, and it did not start anything once I plugged the drive back in. I just wanted to make sure it was mirroring correctly, which it is.
The WD literature states that once you replace a faulty caviar green drive with a fresh one, to not access the drive for 12 hours so it can rebuild. Maybe it will only initiate the rebuild if you plug in an unformatted blank drive.
I am not too worried about the rebuild process, as long as its mirroring correctly.
Vip 222k External HD
Spot Beam from Atlanta in Albnay GA
