Hello all!
I've been collecting up surplus satellite gear over the past few years, and lurking here on and off in an attempt to keep up with FTA goings-on. I've installed my own DBS setups on several occasions, but that's about all the more experience I have with installing satellite equipment.
Today I finally decided to take the plunge. I set a post in the yard, mounted a Channel Master 1.2m round dish (formerly used for Muzak reception), and ran about 60' of RG6 from it to my Coolsat 4000. So far so good.
But then, decision time: I have here three choices for an LNB. There's a no-name one that came with the dish, one taken from a 1.2m Primestar dish (has separate H/V outputs), and a CalAmp 31186 that appears to be new.
First I hooked up the CalAmp unit. I tried various settings on the Coolsat (13V, 18V, "ON", etc) but couldn't get the power LED to turn on. Double-checked cabling, ends, etc - no problems. I pointed the dish at AMC-1 and checked the signal strength on the Coolsat... nothing, of course.
I did the same dance with the generic LNB with similar results. Only difference was that this one has no power indicator, so no way of knowing if it was working or not.
Then, out of desperation, I bolted up the Primestar LNB and tried both the horizontal and vertical outputs. Strangely enough the Coolsat showed a signal strength of around 80%, but the signal quality was around 2-4%. Scanning produced nothing (of course). Results were the same regardless of which output I tried.
I get the feeling I'm missing something here, but my lack of experience is preventing me from seeing what. Anybody have any ideas?
from another Minnesotan
