I just had this system removed from my rig to upgrade to a Winegard HD antenna. The KVH was working before removal. I have some folks interested in buying it so I wanted to show them it works. Is there anything special I need to do? I tried running 12volts to the terminals, but when connected I am only getting 4 volts across the terminals. If I take the wires off and put the multimeter on them, I get 13+ volts. I have the communication cable connected to an old DirecTV receiver, just like when it was installed and have it also connected to the terminal block.
Could it be as simple as the wires running the 12 volt are just too long and I am getting a voltage drop under load, or am I doing something wrong? I am not sure what to do with the "shield" terminal on the terminal block.
