Lip sync issues on PBS 125W Ch-3
$835.00
rzg00
22
California
While watching the PBS Newshour this evening (with timeshift enabled) I noticed a lack of lipsync so I started to record the evidence.... Lips then appeared to synched with the audio! (though the program had shifted from the studio to live republican convention coverage).
I've noticed other lipsync issues on PBS (last nights Masterpiece mystery foe example) but its not universal - anyone else noticed this?
Next time this happens, what's the best way to determine if it's the source or the MicroHD that's suspect?
I have noticed this on one of of the test TVs connected with HDMI, but on other HDMI connected TVs the lip sync is exact. Often a feed might have sync issues than the studio is correct, not much can be done on the viewers side for this production issue. Some TVs have a lip sync adjustment for timing issues affecting all programming from a connected device, most do not. HDMI 1.3 can incorporate a lip sync handshake between devices, but it doesn't calibrate on a per channel basis.
We are investigating adding a menu function in the microHD for adjusting +/- lip sync delay. If the adjustment is made to compensate for one service, another will be off. There is no way to link this feature to the channel list.
Unfortunately I'm still stuck in an analog world and connect to my TV via the AV breakout cable :-( if that makes any difference.
wowsers, you're into professional commercial receiver feature territory with that feature! I would like to see it implemented with the remote -- two buttons to represent (+ lip sync) and one with (- lip sync) -- and the user can fix the lip sync problem to taste on a temporary basis while losing the setting on the next sat or channel change since the lip sync issue was probably only temporary in nature.
Cost effective rack mount MPEG4.
Exactly why we are working on the feature. :D
Yeah boy, if it's easy to operate it will get used.
I would like to emphasize that we are working on a solution. It may or may not be possible to implement.
When breaking new ground and going beyond the chipset design and SDK, we experience a lot of trial and error. What appears to be easy and only an On/Off trigger, often cascades into normal functions ceasing to function.
Thank you for your understanding!
that's why I suggested some buttons on the remote instead of thru menu.
I find it a PITA on a menu system of a commercial receiver. Even if it's on the menu of the microHD, it wouldn't be as convenient as by remote but it wouldn't be too bad because the microHD menu doesn't have as many deep menu trees as a lot of commercial receivers.
It would likely be a submenu item after pressing the Green color Audio key.
Completely understand! It is just so nice to have someone that is as passionate about it as us "power" users are, to push the limits and at least try to see what kind of features can be added. :) .....and actually add them when possible.:eureka:
Possible bug MicroHD
Don't move motor while scanning feature
