Hard to draw with characters, especially when the forum fights ya.Code:[FONT=Fixedsys].. [/FONT][FONT=Fixedsys](off)[/FONT][FONT=Fixedsys] _______ Pansat _____ Gbox _____Perfect 10 | / 3500 [/FONT][FONT=Fixedsys]3200-->|---| / [/FONT] [FONT=Fixedsys] | | / |----- relay | ^ \ | | | \ BLSA-->|---|__mmmm__| \ | (RFC) \_______ Fortec _____ 2100 _____Primestar 84e [/FONT][FONT=Fixedsys] (on)[/FONT][FONT=Fixedsys] 5400 motor [/FONT]
The "mmm" (RFC) is an RF choke, and serves the same purpose discussed in the thread about losing RF signal through 2100 motors.
The poorly drawn diodes --->|---- keep the voltages of the BLSA out of the 3200.
The above assumes you can control LNB power from either the 3200 or BLSA and turn it on or off to select your source, using a relay.
Since STBs let you turn on/off LNB power for each satellite, I thought we could use the same concept here.
The power coming from either the BLSA or the 3200 is only on when you are actually doing something with the software.
You either have to be scanning with Transedit, analyzing with Transedit, running a sweep with the BLSA, or a skyscan with the BLSA to have the power on. It is not on full time out of either card.
I have found it very convenient for instance to have the Pansat scanning say the Vertical side of a satellite, run a sweep at the same time, and if I find something interesting run an analysis with the BLSA program still open.
The "diode" steering hi-freq splitter allows me to do that without fear of burning up either pretty expensive card.
Now, why would I want to build something that I would have to learn how to build, then solder it together and hope it works when I have a perfectly good piece of equipment here already paid for and all I have to do is test it?
If it doesn't test out, I may look for alternatives but would probably opt to buy something that fits rather than try and make it.
