Looking to track a bird on inclined orbit
nupdyxa
6
Cheers to satellite hobbiest.
I am thinking to build a system with a primitive tracking mechanism for satellite on an inclined orbit. Inclination is +- 1.6 degree in Ku band.
As one of the solutions I thought to use an actuator say from a BUD and affix it to 1m dish so that it would move it up and down. Then set up the control box to send a pulse once in a while, depending on the step of an actuator. Though I do not have any practise with actuators or other tracking gears.
Any other suggessions?
Thanks...
Sounds interesting! What inclined satellite are you trying to track?
You also need to be able to move left and right.
Sats in inclined orbit move in a figure-8 pattern.
Also are you sure that you can see the transponder on T11? Some point to America, some to Europe.
T11 used to be able to pick up a few channels on this satellite at one point!
Fair assumption, though if tilt (or skew) on a dish is set right, I believe it would do not exactly 8, but Italic I.
Now, I setup a new dish today. It is elliptical Direcway dish. I chose this one because it has somewhat larger beamwidth in one axis, thus allowing for wider satellite drift. I played with it today, and gotten some discouraging data. The signal was very strong at 6-7 PM tonight, quality jumped to 99% on my Fortec LTU. Then it had slowly started to detiorrate. By 9PM it was gone completely. Any attempts to tweak the dish in az/el and skew axis did not yield any improvement. I tracked it with a Spectrum Analyzer HP8590A The signal just faded completely. Meaning once the satellite drifts up or down it moves the footprint as well. I just cannot understand how much the footprint moves though. If inclinations is 1.6 degree, does not that mean that the reception dish just virtually moves 1.6 degree north/south, say from NY city to New Haven or something??
Any comments?
Any comments?
What degree is this sat at?
Thanks...
Look here ( 1224EL ) and scan down for the only solution I know of that matches what your talking about.
Cold Winter said:
Look ( 1224EL ) and scan down for the only solution I know of that matches what your talking about.
Thanks for a good link.
I guess I need to read up more on Inclined orbit theory. My understanding was that even though the orbit is inclined, the receive antenna can pick up a signal at any given time of a day (if properly aligned of course). In other words the signal is more or less stable, just dish needs constant alignment. Clearly what I am seeing is not the case. During the time satellite passes over equator the signal is high 12-15 dB over the noise floor. Few hours later the signal is gone completely, not a blimp. Any thoughts?
I used 1m DirecPC dish with Invacom SNF-031 LNB.
You should be able to gather orbital predicts from the Sat Controler...This helps in alignment...But a Tracking Rx tuned to the Beacon is your best bet....
Winegard dish declination angle
European Sat. from USA?
