Lost my external Hard Drive
tdenton1138
102
Tucson, AZ
Its not that this hasn't happened before on occasion. Sometimes it will drop out on a reboot, but after one or two restarts I've always manage to get it to come back online. I've now been stymied on 5+ (?) attempts. Has anyone else had this problem or have any suggestions?
Antec MX-1 case with a 1.5 gb drive (Barracude 7200.11) - this setup has worked fine for a couple of years
Thinking about it, I suppose the hard drive could have failed somehow, but the only way to check would be pull the drive and try to run some diagnostics but I'd hate to wipe it out. On the other hand, if I can't get it to work another way...
edited for additional info while I reboot once again: This is on an HR20-700. When I reboot, the "Running receiver self-check" screen will be up for something like 10 or more minutes (haven't timed it)...
Ah ha, for the first time I get this error:
A problem has been detected in the storage device.
This may be a simple initialization error or a critical fault.
Please reboot the box now. That may fix the problem.
If that does not work then call Customer Service at 1-800-DIRECTV
and report the diagnostic code displayed below.
Diagnostics Code: 75-043
Looks to me like I need a new hard drive... Any other suggestions or perhaps just an updated suggestion on hard drives?
Further update: Ok, I pulled the drive from the enclosure and tried it with my external usb cable setup and it doesn't even show up other than the computer sees a usb device (which is just the adapter). The drive is spinning (interesting rotational forces when to hold it), but it seems dead otherwise. I tried to initialize it and it failed. So, aside from getting the same drive, what suggestions might anyone have?
Ok, so the drive failed Seagate's diagnostic tools and turns out to be under warranty (!), so we'll see what happens when I return it.
H25 CE for Labor Day Weekend
CHR2X CE for Labor Day Weekend CANCELED for Saturday Night!
